*writemodelcheckresultfile
Writes out model check results to a file.
*writemodelcheckresultfile filename filetype
HyperMesh Tcl Modify Command
- filename
- The full path and name of the file to write. By default it will be given a .txt extention if not specified.
- filetype
- 0 or 1 - Only the failed count associated with the checks is written out
Examples
To write results to the file C:/temp/check_results.txt
*writemodelcheckresultfile C:/temp/check_resutls.txt 1
# Handle error
}Version History
2019
