*solid_split_by_tool
Splits solid geometry using various tool types.
*solid_split_by_tool solid_mark=<value> tool_type=<value> ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optonN>=<valueN>?
HyperMesh Tcl Modify Command
- extend_trimmer=<value>
- Specifies the behavior of extending the trimming surface when tool_type=bounding_lines, tool_type=surfaces, or tool_type=sweep_lines. Valid values are:
- line_mark=<value>
- The ID of the mark containing the input lines when tool_type=bounding_lines or tool_type=sweep_lines. Valid values are 1 and 2.
- plane_base="<value1> <value2> <value3>"
- The plane base coordinates when tool_type=plane.
- plane_normal="<value1> <value2> <value3>"
- The plane normal direction vector coordinates when tool_type=plane.
- solid_mark=<value>
- The ID of the mark containing the solids to split. Valid values are 1 and 2. This is mandatory.
- split_positions="<value1x> <value1y> ?<value2x> <value2y>? ... ?<valueNx> <valueNy>?"
- When tool_type=plane or when extend_trimmer=1, the trimmer might cut the solids at several sections. This optionally specifies the sections to use for trimming, by giving a point location on each section.
- surf_mark=<value>
- The ID of the mark containing the trimming surfaces when tool_type=surfaces. Valid values are 1 and 2.
- sweep_direction="<value1> <value2> <value3>"
- The sweep direction vector coordinates when tool_type=sweep_lines.
- sweep_distance=<value>
- The optional limited sweep distance when tool_type=sweep_lines.
- tool_type=<value>
- Specifies the tool used to split the solids. This is mandatory. Valid values are:
Examples
*createmark solids 1 2
*createmark lines 2 574
*solid_split_by_tool solid_mark=1 tool_type=sweep_lines line_mark=2 "sweep_direction=0 0 1" extend_trimmer=1*createmark solids 1 2
*createmark lines 2 32 37
*solid_split_by_tool solid_mark=1 tool_type=bounding_lines line_mark=2 extend_trimmer=1*createmark solids 1 2
*solid_split_by_tool solid_mark=1 tool_type=bounding_lines line_mark=2 extend_trimmer=1 "split_positions=0.4 -0.8 0.0 0.5 -0.01 -0.07"
# Handle error
}Version History
2021
