*reconcilemasslocation
Reconciles all locations of a mass to actual locations, and synchronizes the ghosts with actual locations.
*reconcilemasslocation mark_id
HyperMesh Tcl Modify Command
Reconciles all locations of a mass to actual locations, and synchronizes the ghosts with actual locations. If any ghosts are not synchronized with actual locations, they are lost.
- mark_id
- The ID of the mark containing the masses to reconcile. Valid values are 1 and 2.
To reconcile masses with IDs 10 and 20:
*createmark masses 1 10 20
*reconcilemasslocation 1
# Handle error
}Version History
2017.2
