*moveincludecontents
Moves the contents of one include to another, with an option to delete the source include.
*moveincludecontents source_id source_shortname dest_shortname delete
HyperMesh Tcl Modify Command
This command moves the contents of one include to another, with an option to delete the source include.
- source_id
- The ID of the source include file. If this is not available, use 0 and specify source_shortname.
- source_shortname
- The shortname of the source include file. This is only used if source_id is 0 or cannot be found. If this is not required, specify double quotes "".
- dest_shortname
- The shortname of the destination include file.
- delete
- Flag to indicate if the source include should be deleted. Valid values are:
To move the contents of include with shortname front_door to include with shortname front_door_new, deleting the source include:
*moveincludecontents 0 "front_door" "front_door_new" 1
# Handle error
}Version History
10-SA1-120
