*cleanupmodelfile
Cleans up model specific data after a box trim operation.
*cleanupmodelfile mark_id x0 y0 z0 x1 y1 z1 operation
HyperMesh Tcl Modify Command
This command cleans up model specific data after a box trim operation.
- mark_id
- The ID of the mark containing the input entities. The use depends on the
operation argument. Valid values are 1 and 2. Supported entity types include:
- Groups
- Controlvols
- Loads
- x0
- Lower bound x-coordinate.
- y0
- Lower bound y-coordinate.
- z0
- Lower bound z-coordinate.
- x1
- Upper bound x-coordinate.
- y1
- Upper bound y-coordinate.
- z1
- Upper bound z-coordinate.
- operation
- The operation to perform. Valid values are:
- deleteoutsidebox
- Deletes all elements, connectors, blocks and groups outside the specified box.
- deleteemptyunused
- Deletes all empty comps, assems, sets, contactsurfs, outputblocks, groups, plies and rigidwalls, and all unused mats, props, sets, beamsects, curves, systems, vectors, laminates, plies and tables. mark_id and x0 through z1 are ignored.
- preservesolverdata
- Preserves all control cards by adding them to mark_id. x0 through z1 are ignored.
- postclean
- Delete the rest of the items not on mark_id. x0 through z1 are ignored.
Examples
*createmark elems 2 "by box" $x0 $y0 $z0 $x1 $y1 $z1 0 "outside" 1 0 0
*cleanupmodelfile 2 0 0 0 100 100 100 "deleteoutsidebox"
*cleanupmodelfile 2 0 0 0 0 0 0 "deleteemptyunused"*createmark comps 1 all
hm_getincludeisolationentitiesmark 1 2 1 1
*cleanupmodelfile 2 0 0 0 0 0 0 "preservesolverdata"
if { $template_type == "lsdyna" } {
*solverdeckcleanup LsDyna 2
*cleanupmodelfile 2 0 0 0 0 0 0 "postclean"Errors
# Handle error
}Version History
11.0.130
