*messagefileset
Writes certain messages to a file.
*messagefileset type file
HyperMesh Tcl Modify Command
Writes certain messages to a file. All values below are case insensitive.
- type
- The type of message to write. Valid values are:
- file
- The full path and filename of the file to write the messages to.
To save all FE-input error messages to a file named C:/test.dat:
*messagefileset "feinput" "C:/test.dat"
*messagefilefilter "feinput" "error"
# Handle error
}Version History
10-SA1-120
