*CE_ConnectorCombine
Combines connectors.
*CE_ConnectorCombine markMask tolerance
HyperMesh Tcl Modify Command
Combines connectors. Locates connectors that are considered subsets of other connectors within a given tolerance, makes supersets from the connectors having at least one common link entity, and deletes the original subsets.
- markMask
- The mark mask (1 or 2).
- tolerance
- The maximum distance between two connectors that are considered to be duplicates.
Examples
*CE_ConnectorCombine(1, 0.05)To make a combination possible, connectors must have at least one shared link entity.
Currently supported for connectors located at geometric points only.
