*hf_setTLPOL
Moves the specified line to the specified component and sets it as TL or POL.
*hf_setTLPOL suffix color line_id flag_TL flag_POL
HyperMesh Tcl Modify Command
This command moves the specified line to the specified component and sets it as TL or POL.
- suffix
- The component suffix.
- color
- The component color. Valid values are 1 through 64.
- line_id
- The ID of the line of interest.
- flag_TL
- Flag that indicates whether to set the line as TL. Valid values are:
- 0 - Do not set as TL.
- 1 - Set as TL.
- flag_POL
- Flag that indicates whether to set the line as POL. Valid values are:
- 0 - Do not set as POL.
- 1 - Set as POL.
*hf_setTLPOL "TL" 7 22 1 0Errors
# Handle error
}Version History
11.0
