*tablecontour
Contours node/element data from a table.
*tablecontour table_name table_id_column table_value_column legend_title
HyperMesh Tcl Modify Command
- table_name
- The name of the table containing the data to contour.
- table_id_column
- The title of the column in the table that contains the IDs of the entities to contour.
- table_value_column
- The title of the column in the table that contains the values to use for the contour.
- legend_title
- The title to use for the contour legend.
To create a contour of data in table "contour_table", with the column labeled "IDs" as the ID column, the column labeled "Values" as the value column, and a legend title of "My Values":
*tablecontour contour_table IDs Values "My Values"
# Handle error
}Version History
13.0
