*hwCfdSceneShowAll
Turns on the display of all the entities.
*hwCfdSceneShowAll ?consider_geom? ?consider_elems?
HyperMesh Tcl Modify Command
This command is used to turn on all entities.
This should be used in conjunction with the *hwCfdSceneShowHideIsolateEntity and *hwCfdSceneReverseAll commands.
This command is valid only for the CFD profile.
- consider_geom
- 0 - Do not consider the associated geometry
- consider_elems
- 0 - Do not consider the associated elements
Examples
To hide surfaces 1-10, reverse the display, then show all entities:
*createmark surfaces 1 1-10
*hwCfdSceneShowHideIsolateEntity hide surfaces 1 1 1 1
*hwCfdSceneReverseAll surfaces 1 1
*hwCfdSceneShowAll 1 1
# Handle error
}Version History
2019
