*createpositionformech
Creates a new position for a mechanism.
*createpositionformech name
HyperMesh Tcl Modify Command
The mechanism must have the enabled flag set to true for this to be possible.
- name
- The name of the position to be created. If the provided name already exists, an incremental name will be used.
To create a new position with name newposition:
*createpositionformech newposition
# Handle error
}Version History
14.0.120
