*createintersectionsegments
Creates intersection segments as plot elements from the results of hm_collisioncheck.
*createintersectionsegments collector
HyperMesh Tcl Modify Command
Creates intersection segments as plot elements from the results of hm_collisioncheck. hm_collisioncheck must be run with the save_segments option specified before running this command. This command must also be called before hm_collisionend is called.
- collector
- 0 - Create segments as plot elements in a component named ^intersection_segments.
Examples
*createmark surfs 1 1-10
hm_collisioninit
hm_collisionentitycreate surfs 1 0 1 0 0 0 0 0 0
hm_collisioncheck 0 0 1 0 0 0 0 90.0 1
*createintersectionsegments 0
hm_collisionend
hm_getmark surfs 1Errors
# Handle error
}Version History
12.0
