*edgesmarkrestorejoints
Restores previously suppressed fixed points on edges.
*edgesmarkrestorejoints mark_id
HyperMesh Tcl Modify Command
This command restores previously suppressed (by using *verticesmarksuppress) fixed points on selected surface edges.
- mark_id
- The mark ID of input surface edges. Valid values are 1 and 2.
*createmark lines 1 99
*edgesmarkrestorejoints 1Errors
# Handle error
}Version History
12.0.110
