*mechapplyediposition
Applies a position to a mechanism.
*mechapplyediposition mode run_solver
HyperMesh Tcl Modify Command
Applies a position to a mechanism. This will be always used in conjunction with *mechcontructfromedi.
The mechanism must have the enabled flag set to true for this to be possible.
- mode
- The mode for the position:
- run_solver
- 0 - Directly apply the position to bodies without considering constraints and joints.
Examples
To apply position with ID 3 on mechanism with ID 1:
*mechconstructfromedi 2 3
*mechapplyediposition 1 0
To apply the initial position on a mechanism:
# Handle error
}Version History
14.0.120
