*surfacemarkremoveallpinholes
Removes all pinholes of a specified size from the specified surfaces.
*surfacemarkremoveallpinholes mark diameter
HyperMesh Tcl Modify Command
- mark
- The mark ID containing the surfaces.
- diameter
- The upper-limit of the pinhole’s diameter.
*createmark(surfs,1) all
*surfacemarkremoveallpinholes(1,5.0)The *createmark() command is required.
