*addincludetodisplay
Adds the entities contained in the specified include file to the current display.
*addincludetodisplay id shortname
HyperMesh Tcl Modify Command
This command displays/unmasks all of the entities in the specified include file to the HyperMesh modeling window.
- id
- The ID of the include file. An ID of 0 selects the master file. If not specified, should be blank "".
- shortname
- The shortname of the include file. This value can be blank when id is specified. If not specified, should be blank "".
Examples
To add the entities in the include with ID 3 to the display:
*addincludetodisplay 3 ""
*addincludetodisplay "" elems.femErrors
# Handle error
