*hf_ResetDFRibs
Reset the ribs attribute.
*hf_ResetDFRibs int_flag
HyperMesh Tcl Modify Command
- fixed
- drag
- int_flag
- Integer dummy value. Should always be set to 0.
*hf_ResetDFRibs 0Errors
# Handle error
