*linelistbypath
Creates a line path from the starting line to the ending line.
*linelistbypath line_id1 line_id2 list_id flag
HyperMesh Tcl Modify Command
- line_id1
- The ID of the first line.
- line_id2
- The ID of the second line.
- list_id
- The ID of the line list to populate. Valid values are 1 and 2.
- flag
- 0 - If both line_id1 and line_id2 lie are free edges, the path will follow free edges where possible. Otherwise, the shortest path is returned.
To determine the path between lines 100 and 110 using the shortest path:
*linelistbypath 100 110 1 1
# Handle error
}Version History
11.0.101
