*midsurface_remove_display_plates
Deletes components that show the plate information present in the model.
*midsurface_remove_display_plates delete_plate_info remove_from_all_comps reserved1
HyperMesh Tcl Modify Command
The command deletes components that show the plate information present in the model. The command can also be used to delete all the plate and thickness information present in the model.
- delete_plate_info
- This specifies whether, besides deleting the plate information components, the plate information itself should be deleted. Valid values are:
- remove_from_all_comps
- Specifies whether to delete the plate information from the entire model or just from specific components where the plate edit is performed. Valid values are:
- reserved1
- Reserved for future use. Must be set to 0.
Examples
To delete the components showing plate information, as well as the plate and thickness information:
*midsurface_remove_display_plates 1 0 0
To delete the components showing the plate information, as well as the plate information itself, from all components:
*midsurface_remove_display_plates 1 1 0
# Handle error
}Version History
13.0
