*hf_Addendum_PrepareLatitudeLine
Finds the latitude lines to drag and organize them into the component ^latitude_lines_drag.
*hf_Addendum_PrepareLatitudeLine int_flag
HyperMesh Tcl Modify Command
This command finds all of the model’s latitude lines to drag and organize them into the ^latitude_lines_drag component.
- int_flag
- Dummy integer value. Should always be set to 0.
*hf_Addendum_PrepareLatitudeLine 0Errors
# Handle error
