*unrealizeengineeringentity
Unrealize an engineering entity.
*unrealizeengineeringentity entity_type entity_id unrealize_mode
HyperMesh Tcl Modify Command
- entity_type
- The type of engineering entity to unrealize.
- entity_id
- The ID of the engineering entity to unrealize.
- unrealize_mode
- 0 - Delete entities from realization. Only current solver/profile is affected.
Unrealize mass with ID 10:
*unrealizeengineeringentity masses 10 0
# Handle error
}Version History
2017.2
