*createsolidsfromshells
Creates solid elements from shell elements.
*createsolidsfromshells entity_type input_mark_id output_mark_id comp_create_option solid_layers fill_gaps delete_shells property_create reserved1 reserved2 reserved3
HyperMesh Tcl Modify Command
Creates solid elements from shell elements. This API currently works only on composite ply-based models for OptiStruct/Nastran and Abaqus. Zone-based models are not supported, nor are metallic models.
- entity_type
- The type of entity that holds the shell elements. Valid values are plies and laminates.
- input_mark_id
- The ID of the mark containing the input entities. Valid values are 1 and 2.
- output_mark_id
- The ID of the mark containing the newly created solid elements. Valid values are 1 and 2.
- comp_create_option
- Organization method for newly created solid elements:
- solid_layers
- Valid if entity_type is set to plies only:
- fill_gaps
- 0 - Gaps between layers will not be filled.
- delete_shells
- 0 - Keep input shell elements.
- property_create
- 0 - No properties created/assigned for created solids.
- reserved1
- Reserved for future use. Must be set to 0.
- reserved2
- reserved3
Examples
*createmark plies 1 "Ply3"
*createsolidsfromshells plies 1 2 0 0 1 1 1 0 0 0 Errors
# Handle error
}Version History
12.0.110
