*acousticmeshinterface
Identifies acoustic cavity interfaces.
*acousticmeshinterface mark_id wetted_node_output_mark_id interface_node_output_mark_id wetted_element_output_mark_id interface_element_output_mark_id wetted_component_output_mark_id acmodl_normal acmodl_intol acmodl_dskneps reserved1 reserved2
HyperMesh Tcl Modify Command
- The wetted nodes on the body: nodes on elements on the interface with the fluid that satisfy the bounding box criteria.
- The interface nodes of the fluid: the nodes on the fluid faces that are on faces that have at least one body node within their bounding box.
- The wetted element faces of the body: the elements on the body that contain at least one node within a bounding box.
- The interface faces of the fluid: the fluid faces that have at least one body node within their bounding box.
- The wetted body components: the components that contain at least one element on the body that has a node on the wetted interface.
It should be noted that the body is composed of the structural and the seat components.
- mark_id
- The ID of the mark containing the acoustic cavity components for which the faces are considered for building the bounding boxes. Valid values are 1 and 2..
- wetted_node_output_mark_id
- The ID of the mark containing the found wetted body nodes. Valid values are 1 and 2..
- interface_node_output_mark_id
- The ID of the mark containing the found fluid interface nodes. Valid values are 1 and 2..
- wetted_element_output_mark_id
- The ID of the mark containing the found wetted body element faces. Valid values are 1 and 2..
- interface_element_output_mark_id
- The ID of the mark containing the found fluid interface element faces. Valid values are 1 and 2, if the createcavityfaces option was enabled for *acousticmeshcreate.
- wetted_component_output_mark_id
- The ID of the mark containing the found wetted body components. Valid values are 1 and 2..
- acmodl_normal
- Used to define the (positive) height of bounding box for particular fluid faces. This height is equal to the largest side of the face multiplied by this value, and is in the outward direction.
- acmodl_intol
- Used to define the (negative) height of the bounding box for particular fluid faces. This height is equal to the largest side of the face multiplied by this value, and is in the inward direction.
- acmodl_dskneps
- Used to define the in-plane extension of the bounding box for particular fluid faces. This extension is measured relative to the distance from the center of the face to each corner. This value is the ratio by which the face is extended at each corner.
- reserved1
- Reserved for future use. Must be specified as 0.
- reserved2
Examples
Calculate, and then highlight, the wetted nodes, wetted elements and wetted components for two structural and seat cavities:
*createmark components 1 "AC_Structural.1" "AC_Seat.1" "AC_Seat.2" "AC_Structural.2"
*acousticmeshinterface 1 1 0 1 0 2 0.4 0.2 0.2 0 0
hm_highlightmark nodes 1 h
hm_highlightmark nodes 1 n
hm_highlightmark elems 1 h
hm_highlightmark elems 1 n
hm_highlightmark comps 2 h
# Handle error
}Version History
11.0
