*unsetparameter
Unparameterizes a data name or attribute on a single entity.
*unsetparameter entity_type entity_id data_name_or_attribute row column
HyperMesh Tcl Modify Command
- entity_type
- The type of entity to unparameterize.
- entity_id
- The ID of the entity to unparameterize.
- data_name_or_attribute
- The data name or attribute name/ID to unparameterize.
- row
- The row index of the attribute in a 1D or 2D array. Must be set to 0 otherwise.
- column
- The column index of the attribute in a 2D array attribute. Must be set to 0 otherwise.
To unparameterize attribute LSD_DA1 on entity set 5:
*unsetparameter sets 5 LSD_DA1 0 0
# Handle error
}Version History
14.0
