*midsurface_new_plate
Creates a new plate of the specified type.
*midsurface_new_plate mark_id plate_type use_base_surfaces reserved
HyperMesh Tcl Modify Command
The command creates a new plate from the surfaces on the input mark. The plate component, for visualizing the newly created plate and containing copies of the original model’s surfaces, is also created. If the surfaces on the input mark previously had different plate attributes, their copies in the temporary plate components are deleted.
If the base surface information is set to be taken into account, the command will also do a preliminary check whether the given set of surfaces includes any base surfaces or not. If there is any base surface present and the intended merged plate type is "planar" or "sweep", the command will not do anything.
- mark_id
- The ID of the mark containing the input surfaces. Valid values are 1 and 2.
- plate_type
- This parameter specifies the type of merged plate to create. Valid values are:
- use_base_surfaces
- This specifies whether the user-defined base surfaces will be taken into account when displaying the plate information. Valid values are:
- reserved
- Reserved for future use. Must be set to 0.
To set the surfaces with ID 5-7 to become a new plate of type offset, without including a check for the input mark to contain base surfaces:
*createmark surfaces 1 5 6 7
*midsurface_new_plate 1 2 0 0
# Handle error
}Version History
13.0
