*movemark
Organizes entities into collectors.
*movemark entity_type mark_id name
HyperMesh Tcl Modify Command
Moves entities from one collector to another.
- entity_type
- The type of entity to move. Any collected entity type (aside from master/slave elements) is valid.
- mark_id
- The ID of the mark containing the entities to move. Valid values are 1 and 2.
- name
- The name of the collector to move the entities to. The collector type is determined by the entity_type.
To move all elements from comp1 to comp2:
*createmark elems 1 "by collector name" comp1
*movemark elems 1 comp2
# Handle error
