*morphconnstodoms
Creates general domains for selected connectors.
*morphconnstodoms entity_type mark_id retain_handles create_type
HyperMesh Tcl Modify Command
This command will create a general domain for each of the connectors on the mark. Each general domain will contain all of the elements of the associated connector regardless of their type.
- entity_type
- Valid value is connectors.
- mark_id
- Mark of connectors. Valid values are 1 and 2.
- retain_handles
- 0 - Do not retain handles
- create_type
- 0 - Create as normal general domain
To create cluster type domains for all connectors in the model:
*createmark connectors 1 "all"
*morphconnstodoms connectors 1 0 4
# Handle error
}Version History
9.0
