*split_elements_by_structure_pattern_freeselection
Creates a refined mesh inside a selected area and makes the transition using structured patterns .
*split_elements_by_structure_pattern_freeselection entity_type mark_id refine_size adjacent_layers
HyperMesh Tcl Modify Command
- entity_type
- The type of entity used as input. Valid values are nodes and elems.
- mark_id
- The ID of the mark containing the input entities. Valid values are 1 and 2.
- refine_size
- The element size for the refinement zone.
- adjacent_layers
- The number of adjacent element layers to use for making transitions.
Examples
To refine all elements attached to node 198 to a size of 25, using 1 layer for transtion:
*createmark nodes 1 198
*split_elements_by_structure_pattern_freeselection nodes 1 25 1
To refine elements 175-180 to a size of 0.5, using 2 layers for transtion:
*createmark elems 1 175-180
*split_elements_by_structure_pattern_freeselection elems 1 0.5 2
# Handle error
}Version History
2019
