*updateoffset
Update the definition of offset.
*updateoffset type include_id shortname entity_type pool_id offset
HyperMesh Tcl Modify Command
- type
- Must be set to includefiles.
- include_id
- The include file ID, if shortname is not used.
- shortname
- The shortname of the include file, if include_id is not used.
- entity_type
- The type of entity to update. 0 for all entities under the include file.
- pool_id
- The pool ID for the entities to update. 0 for all of pools.
- offset
- The offset value to assign.
Examples
To assign offset 1000 to all entities in include file 1:
*updateoffset includefiles 1 "" 0 0 1000
# Handle error
}Version History
2019
