*body_split_with_points
Split a set of solids or surfaces along a spline constructed from a series of specified points.
*body_split_with_points entity_type mark_id splinepoints size options
HyperMesh Tcl Modify Command
Splits surfaces or solids using swept lines.
- entity_type
- The type of entities being split: solids or surfaces.
- mark_id
- The mark that contains the entities being split.
- splinepoints
- An array of X, Y, Z coordinates for a series of points. HyperMesh uses these points to generate the splitting surface.
- size
- The number of entries in the splinepoints argument.
- options
- Determines the extent of the split:
Examples
*createmark solids 1 1
*createdoublearray 9 1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0
*body_split_with_points solids 1 1 9 0Errors
# Handle error
