*linecreatenormaltogeom
Create a straight segment from a point normal to a geometry.
*linecreatenormaltogeom point_type point_mark_id geom_type geom_mark_id mode
HyperMesh Tcl Modify Command
This command creates straight segment lines from a given set of points or nodes normally to a given set of geometric entities. The segment is created for each pair of point and geometry.
- point_type
- Type of entities representing input points. Valid values are nodes or points.
- point_mark_id
- The mark of input points or nodes.
- geom_type
- Type of geometry entities. Valid values are lines, surfs, faces or solids.
- geom_mark_id
- The mark of input geometry entities.
- mode
- Flags that indicate different modes. Bit values are used and the value is calculated
as (Bit0 + 2*Bit1).
- Bit0
- Parameter that specifies the behavior in ambiguous cases. Valid values are:
- 0 - For each pair of point and geometry, a single segment is created between the point and the closest geometry point. The segment must be normal to the geometry otherwise it is not created.
- 1 - For each pair of point and geometry, a single segment is created between the point and the closest geometry point. The segment does not have to be normal to the geometry.
- Bit1
- Specifies how entities are organized into components. Valid values are:
- 0 - Line is created in the current component, which is the default value.
- 1 - Line is created in the original geometry component.
To create a straight segment normally from node with ID 10 to surface with ID 21:
*createmark nodes 1 10
*createmark surfs 1 21
*linecreatenormaltogeom nodes 1 surfs 1 0
# Handle error
}Version History
10.0
