*contourplot
Creates a contour plot from results data.
*contourplot title legend_min legend_min_value legend_max legend_max_value mesh_color scale_factor full_size reserved vector_comp mult min_max_titles plot_info_title
HyperMesh Tcl Modify Command
Creates a contour plot from results data. The results file must be loaded before executing this command. The *freesimulation command clears the plot.
- title
- The title to use for the plot.
- legend_min
- 0 - Indicates if the minimum value found in the file should be used as the minimum value on the legend.
- legend_min_value
- If legend_mid is set to 1, the minimum value to display on the legend.
- legend_max
- 0 - Indicates if the maximum value found in the file should be used as the maximum value on the legend.
- legend_max_value
- If legend_max is set to 1, the maximum value to display on the legend.
- mesh_color
- The color used to plot the mesh. Valid values are 1 through 64.
- scale_factor
- The scale factor used for scaling a deformed plot.
- full_size
- Determines whether the contour plot fills the entire screen. Valid values are:
- 0 - Use normal size.
- 1 - Use full screen. Press a mouse button to return.
- reserved
- Reserved for future use. Must be set to zero.
- vector_comp
- Vector data type component to use. Valid values are:
- x comp
- y comp
- z comp
- magnitude
- mult
- The value used to multiply the results values.
- min_max_titles
- Indicates if the min/max titles should be displayed. Valid values are:
- 0 - Do not display min/max titles.
- 1 - Display min/max titles.
- plot_info_title
- Indicates if the plot information title should be displayed. Valid values are:
- 0 - Do not display plot information title.
- 1 - Display plot information titles.
Examples
*analysisfileset C:/my_results/test.res
*inputsimulation "Subcase 1" "Displacements"
*contourplot "" 0 0.0 0 0.0 0 0.0 0 0 "magnitude" 1.0 0 0
*freesimulationErrors
# Handle error
