*create_voxel_lattice_mesh
Creates 1D and 2D axis parallel lattice meshes.
*create_voxel_lattice_mesh entity_type_2d mark_id_2d mark_id_1d origin_x origin_y origin_z voxel_size_x voxel_size_y voxel_size_z mesh_extent_x mesh_extent_y mesh_extent_z
HyperMesh Tcl Modify Command
- entity_type_2d
- 2D input entity types. Valid values are:
- surfs
- elems
- mark_id_2d
- The ID of the mark containing the 2D input entities. Valid values are 1 and 2. If no 2D entities are used as input, this should be 0.
- mark_id_1d
- The ID of the mark containing the 1D input entities. Valid values are 1 and 2. If no 1D entities are used as input, this should be 0.
- origin_x
- The coordinates of the domain origin.
- origin_y
- origin_z
- voxel_size_x
- The voxel size discretization along the axes.
- voxel_size_y
- voxel_size_z
- mesh_extent_x
- The boundary of the domain to be considered, specified using the rightmost corner of the domain bounding box relative to the origin. The rightmost extreme of the domain is calculated as (voxel_size_x * mesh_extent_x).
- mesh_extent_y
- The boundary of the domain to be considered, specified using the rightmost corner of the domain bounding box relative to the origin. The rightmost extreme of the domain is calculated as (voxel_size_y * mesh_extent_y).
- mesh_extent_z
- The boundary of the domain to be considered, specified using the rightmost corner of the domain bounding box relative to the origin. The rightmost extreme of the domain is calculated as (voxel_size_z * mesh_extent_z).
Examples
*createmark surfs 1 all
*createmark lines 1 all
*create_voxel_lattice_mesh surfs 1 1 0 0 0 1 1 1 100 100 100Errors
# Handle error
}Version History
14.0
