*hf_FeatureFromSurfaces
Creates the feature line from surfaces.
*hf_FeatureFromSurfaces entity_type mark_id
HyperMesh Tcl Modify Command
This command creates the feature line from selected surfaces. It stitches together all the surfaces to extract a single free edge.
- entity_type
- Must be set to surfs.
- mark_id
- The mark ID containing the surfaces. Valid values are 1 and 2.
*createmark surfaces 1 644
*hf_FeatureFromSurfaces surfaces 1Errors
# Handle error
}Version History
10.0
