*ME_CoreBehaviorAdjust
Adjusts part and part assembly related behaviors based on certain aspects and policies.
*ME_CoreBehaviorAdjust "<aspect1>=<value1>,<aspect2>=<value2>,...,<aspectN>=<valueN>"
HyperMesh Tcl Modify Command
Valid aspects and their policy values are:
- allow_automatic_occurrence_splitting
- Every occurrence has an associated base prototype. A single prototype may provide the base for multiple occurrences (e.g. a prototype of a wheel might have four occurrences in a vehicle). Once automatic splitting is enabled, any modification that may happen in an occurrence will cause it to be separated (split) from its original prototype to a new prototype of its own, containing all the modifications made. In the wheel/vehicle example, changes made to the front left wheel will cause it to be separated in a different prototype, while all the rest of the wheels remain based on the original prototype, thus having now two prototypes instead of just one. Possible values are:
- allowable_actions_policy
- Defines the availability of various actions that operate on parts and part assemblies. Possible values are:
To set the allowable actions policy to TC lite:
*ME_CoreBehaviorAdjust "allowable_actions_policy=TC_lite"
# Handle error
}Version History
14.0
2019 - Added new aspect allow_automatic_occurrence_splitting.
