*findbetween
Finds entities that are between/connect other entities.
*findbetween find_entity_type between_entity_type between_mark_id function numbers output_mark_id
HyperMesh Tcl Modify Command
- find_entity_type
- The entity types to find. Valid values are nodes and connectors.
- between_entity_type
- The entity types that the find entities are between.
- If find_entity_type is nodes, valid values are elems and comps.
- If find_entity_type is connectors, valid values are surfs, elems, tags, assems and comps.
- between_mark_id
- The mark ID containing the between entities. Valid values are 1 and 2.
- function
- Currently only a value of 0 is supported. This finds connectors between surfs, elems, tags, assems or comps.
- numbers
- A flag that determines if the numbers of the found entities will be turned on after
they are found.
- 0 - Off
- 1 - On
- output_mark_id
- The mark ID containing the found entities. Valid values are 1 and 2.
*createmark components 1 "by id only" 1 2
*findbetween connectors comps 1 0 1 2*createmark components 1 "by id only" 1 2
*findbetween nodes comps 1 0 1 2Errors
# Handle error
