*CE_MarkRemoveLinkMark
Remove link entities of a specific type and ID or name from the connectors on mark.
*CE_MarkRemoveLinkMark mark_id link_type link_mark_id update_layer_option
HyperMesh Tcl Modify Command
- mark_id
- The ID of mark for the connectors to be modified. Valie values are 1 or 2.
- link_type
- Specific link type to search in the connector.
- link_mark_id
- The ID of mark for the links to be removed. Valie values are 1 or 2.
- update_layer_option
- Option to update the number of layers after removing links from the connectors:
Examples
To remove component with ID 3 from connectors with IDs 1,2 and 4:
*createmark connectors 1 1 2 4
*createmark components 2 component3
*CE_MarkRemoveLinkMark 1 components 2 1
# Handle error
}Version History
2019
