*renumberinternaltosolverid
Renumbers internal IDs to match solver IDs.
*renumberinternaltosolverid entity_type output_mark_id
HyperMesh Tcl Modify Command
- entity_type
- The type of entity to update. If set to 0, all entities that have solver IDs are considered.
- output_mark_id
- The ID of the mark containing the renumbered entities. Valid values are 1 and 2.
Examples
To renumber all entities:
*renumberinternaltosolverid 0 0
# Handle error
}Version History
2019
