*flattenpartmodel
Converts entities that refer to parts to refer to root.
*flattenpartmodel reserved
HyperMesh Tcl Modify Command
For formula sets:
- All clause – Updated to refer to root
- Range clause – Range IDs of the clause will now refer to the begin/end range equivalent to the internal IDs
- reserved
- Reserved for future use. Must be set to 0.
Examples
*flattenpartmodel 0Errors
# Handle error
}Version History
2020
