*CE_FE_UCCUpdateByDCC
Updates a connector control using a connector control default.
*CE_FE_UCCUpdateByDCC cc_name ccd_name
HyperMesh Tcl Modify Command
- cc_name
- The name of the connector control to update.
- ccd_name
- The name of the connector control default to use.
Examples
Update a connector control named "my_acm" from the connector control default "acm_(general)_spot_nastran_template":
*CE_FE_UCCUpdateByDCC "my_acm" "acm_(general)_spot_nastran_template"
# Handle error
}Version History
2021
