*body_split_with_swept_lines
Splits surfaces or solids using swept lines.
*body_split_with_swept_lines entity_type mark_id line_mark_id vector_id back_dist options
HyperMesh Tcl Modify Command
Input lines are used to construct cutting surfaces, which are then used to trim selected solids or surfaces.
- entity_type
- The type of entities to split. Valid values are solids or surfaces.
- entity_mark
- The ID of the mark containing the entities to split. Valid values are 1 and 2.
- line_mark_id
- The ID of the mark containing the lines from which to to generate the swept surface used for splitting. Valid values are 1 and 2.
- vector_id
- using the *createvector command. This must be set to 1.
- back_dist
- In the case where a limited sweep is specified (see options), this defines the position of the front edge of the cutting surface with respect to the position of corresponding input line. For a value of 0 the front edge coincides with input line. A positive value results in shifting the position of the front edge in the direction of the input vector.
- options
- The options to use for trimming the selected entities. Bit values are used and the
value is calculated as (Bit0 + 2*Bit1 + 4*Bit2).
- Bit0
- 0 - Limited sweep. The swept surfaces are created and used as defined by vector length and back_dist.
- Bit1
- 0 - Limited lines. Original input lines are used to generate swept surfaces.
- Bit2
- 0 - Cutting surfaces become part of the model.
Examples
*createmark solids 1 111
*createmark lines 1 5 6
*createvector 1 0 0 1
*body_trim_with_swept_lines solids 1 1 1 0 3Errors
# Handle error
}Version History
13.0
