*parsesolveroutputfile
Creates tables from solver output files.
*parsesolveroutputfile filename=<value> filetype=<value> extractdata=<value>
HyperMesh Tcl Modify Command
- filename=<value>
- The full name and path of the file to parse.
- filetype=<value>
- The type of file to parse. Valid values are:
- extractdata=<value>
- The type of data to extract from the file. Valid values are:
To generate tables from the flutter data conatined in the file C:/temp/MSCFlutter.out:
*parsesolveroutputfile filename="C:/temp/MSCflutter.out" filetype=F06 extractdata=fluttercurves
# Handle error
}Version History
2019.1
