*AE_AttachmentControlDefaultCreate
Initializes the attachment control defaults.
*AE_AttachmentControlDefaultCreate reserved1 reserved2
HyperMesh Tcl Modify Command
Initializes the attachment control defaults. Must be called before any attachment controls can be used or saved.
- reserved1
- Reserved for future use, must be set to "".
- reserved2
- Reserved for future use, must be set to 1.
Examples
Create an attachment control named "myattachmentcontrol", derived from the rigid spider default:
*AE_AttachmentControlDefaultCreate "" 1
*AE_AttachmentControlCreateFromDefault "myattachmentcontrol" "rigidspider" 1
# Handle error
}Version History
2020
