*hwct_deleterepsfromlibrary
Deletes representations from a connected library.
*hwct_deleterepsfromlibrary entity_type mark_id params
HyperMesh Tcl Modify Command
- entity_type
- The type of connected library. Currently only supported for subsystems.
- mark_id
- The ID of the mark of entities. Valid values are 1 and 2.
- params
- A quoted, comma separated string, containing additional optional name=value
parameters. Valid parameters are:
- comment=<value>
- The comment to add for the action.
Examples
Delete crash representation for subsystem 2 from the library:
*createmark subsystems 1 2
*hwct_deleterepsfromlibrary subsystems 1 crash "removedcrash"
# Handle error
}Version History
2020
