*segmentsetadjustnormal
Adjusts a segment set normal using an orientation element.
*segmentsetadjustnormal name elem_mark_id elem_flag orientation_element reverse_normals
HyperMesh Tcl Modify Command
- name
- The name of the segment set to update.
- elem_mark_id
- The ID of the mark containing the elements to adjust when elem_flag is 1. Valid values are 1 and 2.
- elem_flag
- Flag for reversing the contact normal of all or individual elements of the segment set:
- orientation_element
- The ID of the shell element used to define the segment set normal correction.
- reverse_normals
- 0 - Correct contact normal along orientation_element normal (default)
Examples
*createmark elems 1 12 29 53 23
*segmentsetadjustnormal "test" 1 1 23 0
*segmentsetadjustnormal "test" 1 1 23 1
# Handle error
}Version History
2020
