*includesuppressactive
Sets the active/inactive state of all supported entities contained within the specified include file.
*includesuppressactive include_id include_shortname state
HyperMesh Tcl Modify Command
This command sets the active/inactive state of all supported entities contained within the include file (but not the include file itself) with include_id and include_shortname. Only one of these two options need to be specified, however include_id will take precedence if specified. Double quotes "" must be used for an argument that is not specified.
Include files do not have an active/inactive state, only the entities contained within them.
- include_id
- include_shortname
- state
- The state argument indicates the active/inactive status for the
supported entities contained in the include.
- 0 - Indicates to set the entities to active and turn on their display.
- 1 - Indicates to set the entities to inactive and remove them from the display.
- 2 - Indicates to set the entities to active but not to re-display them.
To set all supported entities contained within include file ID 5 to active and re-display:
*includesuppressactive 5 "" 0
To set all supported entities contained within include file shortname include .txt to inactive:
*includesuppressactive "" include.txt 1
To set all supported entities contained within include file ID 5 to active and not re-display:
*includesuppressactive 5 "" 2
# Handle error
}Version History
9.0
