*createfilletmidlines
Recognize fillet surfaces of triangular or rectangular shape, and split strings of fillets down to their longitudinal center lines.
*createfilletmidlines mark_id max_radius min_radius max_width, min_width suppress_rib
HyperMesh Tcl Modify Command
This command is applied to a selection of surfaces given by mark_id. It first recognizes triangular or rectangular fillet surfaces with radius among the range (min_radius, max_radius), and fillet profile arc length among the range (min_width, max_width). Then it splits the recognized fillets along longitudinal center lines.
- mark_id
- The mark of surfaces. Valid values are 1 and 2.
- max_radius
- The maximum fillet radius (must be greater than min_radius).
- min_radius
- The minimum fillet radius (must be greater than or equal to 0).
- max_width
- The maximum fillet profile arc length (must be greater than min_width).
- min_width
- The minimum fillet profile arc length (must be greater than or equal to 0).
- suppress_rib
- The option for suppressing original fillet tangent lines.
- 0 - Do not suppress.
- 1 - Suppress.
Examples
*createmark surfaces 1 "displayed"
* createfilletmidlines 1 40 0.0001 100000 0 0Version History
9.0
