*solverconvert
Converts a model from one solver to another.
*solverconvert source_solver destination_solver source_type destination_type batch ?config_file_path?
HyperMesh Tcl Modify Command
This command converts a model from one solver to another.
Supported solvers are:
| Solver Name | Solver ID | Solver Type |
| Nastran | 1 | |
| OptiStruct | 1 | |
| Abaqus | 2 | Standard2D, Standard3D |
| ANSYS | 8 | |
| LsDyna | 9 | Keyword971_R8.0, Keyword971_R7.1, Keyword971_R6.1, Keyword971, Keyword970 |
| PAM-CRASH | 18 | Pamcrash2G2015, Pamcrash2G2014, Pamcrash2G2013, Pamcrash2G2012, Pamcrash2G2011, Pamcrash2G2010, Pamcrash2G2008, Pamcrash2G2007, Pamcrash2G2006 Pamcrash2G2005, Pamcrash2G2004 |
| Radioss | 20 | Radioss2017, Block140, Block130, Block120, Block110, Block100, Block90, Block51, Block44 |
| Source Solver Name | Destination Solver Name |
| Abaqus | Nastran/OptiStruct |
| ANSYS | Nastran/OptiStruct |
| LsDyna | Nastran/OptiStruct |
| Radioss | PAM-CRASH |
| PAM-CRASH | Radioss |
| Nastran/OptiStruct | Abaqus |
| Nastran/OptiStruct | ANSYS |
| Nastran | LsDyna |
| Nastran/OptiStruct | Radioss |
| ANSYS/OptiStruct | Abaqus |
| Nastran | OptiStruct |
- source_solver
- The source solver name or ID.
- destination_solver
- The destination solver name or ID.
- source_type
- The source solver template type.
- destination_type
- The destination solver template type.
- batch
- Flag that indicates if the conversion should be run in batch mode.
- 0 - No batch mode
- 1 - Batch mode
- ?config_file_path?
- The full path for the configuration file containing the entity mapping details, to be used for the conversion. This is useful when the user has restrictions on modifying the file in the installation. When the configuration file path is not specified or the path is not valid, the conversion will use the default configuration file from the installation.
Examples
Convert Abaqus Standard3D model to OptiStruct in batch mode:
*solverconvert Abaqus OptiStruct Standard3D "" 1
or
*solverconvert 2 1 Standard3D "" 1
Convert Radioss Block90 model to PAM-CRASH Pamcrash2G2007 without batch mode:
*solverconvert RadiossBlock Pamcrash Block90 Pamcrash2G2007 0
or
*solverconvert 20 18 Block90 Pamcrash2G2007 0
# Handle error
}Version History
11.0
2017.1 - Added a new optional argument config_file_path. Updated list of supported solver versions.
