*separate_holes_in_3d_body_new
Detects holes in 3D models, groups them by diameter and moves the surfaces defining the holes to separate components created for each hole diameter group.
*separate_holes_in_3d_body_new entity_type input_mark_id output_mark_id flags string_array number_of_strings
HyperMesh Tcl Modify Command
This command takes as input a mark of surfaces or solids of a 3D body. It finds holes in the 3D body, collects the found connected holes in tubes, and groups the tubes by diameter either according to the user- specified diameter ranges or by autocreating the groups from the user-specified tolerance. The command creates a component with an autogenerated name for each diameter group and moves the relevant surfaces of the tubes to the corresponding components. Blind-holes and through-holes are considered as different groups, so they are grouped separately. Optionally, the surfaces of the detected holes can be put to an output mark.
The command parameters have the following meaning:
- entity_type
- The type of selected input entites. surfaces and solids are supported:
- input_mark_id
- The input surfaces or solids mark id of the input. Valid values are 1 and 2.
- output_mark_id
- The mark ID to mark the surfaces of the detected holes. Valid values are 0, 1 or 2. If set to 0 the detected holes’ surfaces are not marked.
- flags
- Sets a filter for the shape of cross sections of holes to be recognized. Supported
values are:
- 0 - Holes are not filtered by shape (arbitrarily shaped).
- 1 - Only round holes are detected.
- 2 - Only rounded slots are detected.
- 3 - Both round holes and rounded slots are detected.
- string_array
- The ID of the string array that contains the fillet width and radius group information. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
To recognize round holes with diameters from 0 to 50 in 3D model, separate them in groups by diameter according the ranges: 10-11, 12-15, 17-20, 20-30 and 30-50, allow adjacent tube sections diameter ratio of up to 3.0 and to mark the detected holes surfaces on mark 2:
*createmark surfaces 2 ""
*createmark surfaces 1 "all"
*createstringarray 6 "cross_sect_size_max = 50 diams_ratio_max = 3.0" "10 11" "12 15" "17 20" "21 30" "30 50"
*separate_holes_in_3d_body_new surfs 1 2 0 1 6
*createstringarray 6 "cross_sect_size_max = 50 diams_ratio_max = 3.0" "10 11" "12 15 0" "17 20" "21 30" "30 50"
# Handle error
}Version History
10.0
