*morphpositionshapemark
Positions shapes from one part of the mesh to another, scales them, and applies them only to the nodes on the mark.
*morphpositionshapemark s_entity_type s_mark_id a_entity_type a_mark_id n1 n2 n3 n4 n5 n6 xs ys zs mode scale tol system_id con
HyperMesh Tcl Modify Command
This command will position the shapes on s_mark_id from an orientation defined by n1, n2, and n3 to an orientation defined by n4, n5, and n6, scale them in the x, y, and z directions using either the local or global system, and affect only the nodes on a_mark_id. The shapes may be applied to the mesh, created as new shapes, added to existing shapes, or may replace existing shapes.
- s_entity_type
- Must be set to shapes.
- s_mark_id
- The mark ID of the shapes. Valid values are 1 and 2.
- a_entity_type
- Must be set to nodes.
- a_mark_id
- The mark ID for target nodes. Valid values are 1 and 2.
- n1 n2 n3
- IDs of nodes defining initial position of shape.
- n4 n5 n6
- IDs of nodes defining final position of shape.
- xs ys zs
- Scaling factors for the shapes in the x, y, and z directions.
- mode
- 0 - Apply each shape to the mesh
- scale
- 0 - Do not scale shapes
- tol
- The "envelope" or distance around the translated shape inside which nodes are affected.
- system_id
- ID of system used for scaling factors.
- con
- 0 - Do not use constraints
Examples
To position a shape from one part of the mesh to another and apply it to the mesh:
*createmark shapes 1 1
*createmark nodes 2 "all"
*morphpositionshapemark shapes 1 nodes 2 11 12 13 21 22 23 1.0 1.0 1.0 0 0 3.0 0 1
To position all shapes from one part of the mesh to another, double them in size, and create new shapes, but only on selected nodes:
*createmark shapes 1 "all"
*createmark nodes 2 1 2 3 4 5 6 7 8 9 10 11 12
*morphpositionshapemark shapes 1 nodes 2 11 12 13 21 22 23 2.0 2.0 2.0 4 1 3.0 0 1
# Handle error
}"The original set of nodes do not define a plane." - occurs if n1, n2, and n3 are collinear
"The new set of nodes do not define a plane." - occurs if n4, n5, and n6 are collinear
Version History
10.0
